johnparker99's avatar
johnparker99
New GS308EP says default password is invalid
My new GS308EP is discoverable by NDT and browser page opens login screen with model number. However the password printed on the bottom is considered invalid. Tried Chrome and Edge, including InPrivate
Firmware Version V1.0.1.1
    • ninaleechie's avatar
      ninaleechie
      Hello, I have the same issue with a GS308EPP.  The password "password" does not work.  I bought this new and did not change the password.
      EDIT:  However, factory reset resolves the issue.
  • ErwinL's avatar
    ErwinL
    NETGEAR Moderator
    Hello johnparker99
    Looks like the issue is resolved by resetting the device to it's factory default settings which worked with ninaleechie. Have you tried this yet?
    Have a lovely day,
    Erwin
    Netgear Team
      • ErwinL's avatar
        ErwinL
        NETGEAR Moderator
        Hello johnparker99
        Thank you very much for your response. In this case could you give us a feedback on the situation and accept the post as a solution to make it more visible to other users?
        Have a lovely day,
        Erwin
        Netgear Team
ProSupport for Business
