Jaapst64
Feb 08, 2021Tutor
no ip-adress
This afternoon my switch gives this message. I had some difficulties connecting my STB. XS716T-1 DNS_CLI[dnsTask]: dns_client_util.c(1718) 1468 %% DNS Client: no ipv4 or ipv6 address found in res...
- Feb 09, 2021
Problem is solved by changing the DNS-server adress to a proper one
DaneA
Feb 09, 2021NETGEAR Employee Retired
Was everything working fine before? Are there any changes made within the settings of the XS716T switch or with the network setup?
How is everything connected? It would be best if you can post a your detailed network diagram showing the connected devices.
What is the current firmware of the XS716T switch?
What is STB?
DaneA
NETGEAR Community Team
- Jaapst64Feb 09, 2021Tutor
