jsit
Dec 07, 2019Guide
Offline Registration Key
Just purchased a GS110TPv3 switch and am in the process of initially configuring it offline. Now I need a registration key. I registered it in the mynetgear.com site, but dont see a registration key ...
- Dec 18, 2019
Hi jsit ,
Sorry about the experience on activation key of my.netgear.com.
And this probably issue of my.netgear.com is under analysis , we will update to you while get feedback from developer team.
Otherwise, I have a workaround to get activation key for you.
I will take about 5 minutes for you and No need to connect switch with Internet.
Please reference following step to get the key, it's free to get this workaround works.
1. Install NETGEAR insight application from iOS App Store,
or from Android Google play store.
2. Login with NETGEAR account which registered this switch GS110TPv3.
3. After login with NETGEAR account successful.
Please click on the switch name under "My Other NETGEAR Products"
4. Please click on the button of "Registation Key".After insight load the screen of device.
5. You will find the Registation Key(activation key)for your device GS110TPv3.
6. Please remember this key and keep it private not share to others.
Then Input the Key on Switch Local GUI to unlock all GUI functionality.
7. Enjoy with GS110TPv3.
Here is screenshot of my locally verification.
Hope it works for you.
Thanks,
Daniel.
DaneA
Dec 08, 2019NETGEAR Employee Retired
jsit,
Welcome to the community! :)
I dont want to connect this switch to the internet. How do I obtain the registration key so I can activate all the features???
I advise you to open a chat or online support ticket with NETGEAR Support here at anytime. Kindly state your concern or you may provide the link to this forum thread. Be sure that your contact number is indicated in your MyNETGEAR account. A registration key will be requested to be generated and it will be provided to you.
DaneA
NETGEAR Community Team
jsit
Dec 09, 2019Guide
Allow me to respond to both responses.
- This only started occuring when I updated the firmware to the most recent version availabile right now, 7.0.2.4. Before that we had full access to all features. After is when it started forcing a registration key requirement.
- I have chatted with Netgear support for over an hour. They insisted connecting the switch to the internet was the only way to proceed and could not explain if I had to connect to the internet what the purpose of the Registration Key for offline activation was, or how to obtain it. Thus, my frustrated post on these forums.
