jsit
Dec 08, 2019Guide
Offline Registration Key
Just purchased a GS110TPv3 switch and am in the process of initially configuring it offline. Now I need a registration key. I registered it in the mynetgear.com site, but dont see a registration key ...
- Dec 18, 2019
Hi jsit ,
Sorry about the experience on activation key of my.netgear.com.
And this probably issue of my.netgear.com is under analysis , we will update to you while get feedback from developer team.
Otherwise, I have a workaround to get activation key for you.
I will take about 5 minutes for you and No need to connect switch with Internet.
Please reference following step to get the key, it's free to get this workaround works.
1. Install NETGEAR insight application from iOS App Store,
or from Android Google play store.
2. Login with NETGEAR account which registered this switch GS110TPv3.
3. After login with NETGEAR account successful.
Please click on the switch name under "My Other NETGEAR Products"
4. Please click on the button of "Registation Key".After insight load the screen of device.
5. You will find the Registation Key(activation key)for your device GS110TPv3.
6. Please remember this key and keep it private not share to others.
Then Input the Key on Switch Local GUI to unlock all GUI functionality.
7. Enjoy with GS110TPv3.
Here is screenshot of my locally verification.
Hope it works for you.
Thanks,
Daniel.
jsit
Dec 17, 2019Guide
No, the issue has NOT been resolved. I updated the device firmware to 7.0.25. No changes to the device registration key requirement.
I logged into our MyNetgear portal and now see a new button for "View Registration Key". However, when I click it I receive an error message stating "Selected product doesnt support offline registration".
Images inserted below.
Can you assist?
YeZ
Dec 17, 2019NETGEAR Expert
We will look into the MyNETGEAR site issue. At the same time, can you try to get the Registration Key from Insight Manager the mobile app? The new Insight app should support it too.
Thank you.
