senstech
Feb 05, 2021Follower
On which VLAN do Smart Plus series switches send DHCP requests?
I've come to suspect that the Smart Managed Plus switches will send DHCP requests untagged on all their ports. Is this true? The documentation doesn't seem to help here. If I cannot configure th...
schumaku
Feb 05, 2021Guru - Experienced User
No other way than using a static IP address in this use case.
The limitation is that the microcontroller on the Smart Managed Plus system does sit on all VLANs untagged, a management VLAN can't be configured. Please be aware that the static IP is reachable on all VLANs therefore, too.
