senstech
Feb 05, 2021Follower
On which VLAN do Smart Plus series switches send DHCP requests?
I've come to suspect that the Smart Managed Plus switches will send DHCP requests untagged on all their ports. Is this true? The documentation doesn't seem to help here. If I cannot configure th...
hansbogert
Jan 01, 2024Aspirant
Ran into this as well, this is pretty braindead tbh because this is security sensitive. In my case the switch decided from one day to the other to start using my ISP's DHCP offer and suddenly the management interface was on the public internet. And my normal router got its DHCP lease removed.
This should be advertised with capital letters in the documentation.
schumaku
Jan 01, 2024Guru - Experienced User
No: Nothing the switch decides. Purely random which DHCP server does answer first when connected to a single broadcast domain. Your ISP does allow only one MAC address on the router, and is unable to provide additional public IP addresses. Affected devices fail back to ZeroConf addresses, others to default IP addresses.
For users desperate to deploy a switch - why ever, one possible reason might be configuring a mirroring port for capturing all Internet traffic, assuming people know what they do, between the WAN device (like cable modem, fiber termination boxes [FTP], optical termination boxes [OTP], bridged DSL modem, or bridged Starlink boxes) - if this can't be avoided, community members are suggesting to deploy alternate switches supporting management VLANs, or at least deploy static LAN IP addresses. Either way, it's not a usual, standard installation. That's why no bold warning is required.
