WojtekC's avatar
WojtekC
Guide
Feb 19, 2021
PoE options in GS324TP S350 Series
Hello,   Can someone explain to me meanings of PoE options in "Poe Port Configuration" menu, especially "Power Mode" and "Detection type"? Or point me to appropriate documentation?
  • schumaku's avatar
    Feb 20, 2021
    The wonders of the tiny (?) top right in the switch web UI - it's the switch Web UI online help.
    Needless to say, there is typically no reason to change anything away from the defaults - unless there is a specific requirement and you exactly know what (and why) you migth do it.
ProSupport for Business
