Gary12
Sep 30, 2022Tutor
ProSafe GS108Ev3 VLAN failure
Below is my network setup. Gateway: Ubiquiti UniFi Security Gateway 3P (USG-3P) Port 1: WAN (Internet) Port 2: LAN (Trunk port, Untagged VLAN1 and tagged VLAN13 and VLAN15). Laundr...
- Oct 28, 2022
I found the problem. The configuration of the VLANs on the Unifi router was different than the Netgear switch.
Subnet
Subnet VLAN Unifi VLAN Netgear 192.168.13.0/24 3 13 192.168.14.0/24 4 14 192.168.15.0/24 5 15 After changing the VLAN on the Netgear switch, all tests pass!
Thanks everyone
Retired_Member
Oct 04, 2022
You defined all your switchports as trunk ports. An access port should be an untagged member of a single VLAN and have its PVID set to the VLAN ID.
Port 6: Untagged in VLAN 13, PVID=13
Port 7: Untagged in VLAN 15, PVID=15
Gary12
Oct 05, 2022Tutor
For this test, I wanted the netgear switch to have only trunk ports. It is not passing tagged traffic. My question is why?
- Apr 12, 2023Retired_Member
