jbouwh
Sep 13, 2012Tutor
Prosafe Plus Configuration Utility - HTTP request error
I own two Netgear Smart swiches: Regards, Jan
- Oct 09, 2012I Fixed it!!! :): The problem seemed to be caused by the 'Internet Connection Sharing Service (ICS)'.
Some how I have been configuring this service on my laptop. When I stop this service, the utility works again. Because I do not need this service most of the time I changed the startup mode of this service to manual.
DaneA
Jan 14, 2016NETGEAR Employee Retired
Hi Shak7,
Congratulations!!! :) I am glad that you have isolated the problem and got it working. Thanks for sharing your experience and the solution you did to resolve the problem.
Feel free to post your future concerns here in the community!
Cheers,
DaneA
NETGEAR Community Team
chiefwebofficer
May 14, 2016Aspirant
I had the same problem. My OS is Windows 8. Set the exe for the utility to Windows 7 compatibility. Works now.
- DaneAMay 15, 2016NETGEAR Employee Retired
Hi chiefwebofficer,
Welcome to the community! :)
I am glad that your problem has been resolved and I appreciate that you have shared your experience here in the community. :)
Cheers,
DaneA
NETGEAR Community Team - Toni_ToniMay 27, 2016Aspirant
Hi,
I have the same error, NetGearServer.exe crashes when opening the utiliy (v2.3.19).
I could fix it by disabling all the other NICs (22 adapters and 10 teams).
Would be nice if this issue would be fixed by Netgear...
Toni
