jbouwh
Sep 13, 2012Tutor
Prosafe Plus Configuration Utility - HTTP request error
I own two Netgear Smart swiches: Regards, Jan
- Oct 09, 2012I Fixed it!!! :): The problem seemed to be caused by the 'Internet Connection Sharing Service (ICS)'.
Some how I have been configuring this service on my laptop. When I stop this service, the utility works again. Because I do not need this service most of the time I changed the startup mode of this service to manual.
jbouwh
Sep 14, 2012Tutor
It might be Air, but the error are caused by the Netgear EXE files I mentioned. Those apps make SOAP webservice that is called by the Air app.
When I remove Adobe Air and the reinstall the utillity, it will install an ald version of Adobe Air, but that does not solve anything either.
