jbouwh
Sep 13, 2012Tutor
Prosafe Plus Configuration Utility - HTTP request error
I own two Netgear Smart swiches: Regards, Jan
- Oct 09, 2012I Fixed it!!! :): The problem seemed to be caused by the 'Internet Connection Sharing Service (ICS)'.
Some how I have been configuring this service on my laptop. When I stop this service, the utility works again. Because I do not need this service most of the time I changed the startup mode of this service to manual.
jbouwh
Oct 09, 2012Tutor
- SpenceVJul 27, 2015Aspirant
Ok so confirmed ICS needs to be disabled. But the issue is bigger than that I think if you have vitural box VMware ot hyper-v running they will create a similare issue. i got around it by disabling all of the other Nics on the systems. did my config and updates then re-enbled them and re-enabled ICS.
(note: it for ICS comon to be runing so you should proably set it back to enabled when done)
PS ICS is a really usfull tool not a troubleing service.
- oekDec 31, 2015Aspirant
I have the same issue (Win 10 Pro 64 bit). Neither ICS, nor VMware oder HyperV services are running. No chance to open ProSafe Utility? Netgear, pls fix this!
- JohnRoJan 01, 2016NETGEAR Employee Retired
Hello oek,
Welcome to the community!
It could be a different case now compared to what was mentioned in this thread, the Win10 is a newer OS and had some changes. We need to know the following:
- Model and version of your unit.
- Firmware version
- Utility version
Looking forward to your response.
Thanks,
