jbouwh
Sep 13, 2012Tutor
Prosafe Plus Configuration Utility - HTTP request error
I own two Netgear Smart swiches: Regards, Jan
- Oct 09, 2012I Fixed it!!! :): The problem seemed to be caused by the 'Internet Connection Sharing Service (ICS)'.
Some how I have been configuring this service on my laptop. When I stop this service, the utility works again. Because I do not need this service most of the time I changed the startup mode of this service to manual.
jbouwh
Feb 19, 2013Tutor
jeffbrl wrote: Can you reproduce the problem by re-enabling ICS? I am experiencing the same problem. While I've had ICS enabled in the last few weeks, it's currently disabled.
Jeff L.
Hi Jeff,
Yes I can reproduce this. I just tried it. Make sure you don't have any connections that have that have checks on the sharing properties tab.
Jan
