vescovo
Aug 10, 2024Aspirant
PVID vs VLAN member vs VLAN tag
Hi All! First day on holiday but still thinking about some hypotesis I talked with a collegue of mine on last day of work. Please see here: I know that "standard" config is (ie): P...
schumaku
Aug 10, 2024Guru - Experienced User
The PVID defines the VLAN untgged frames will be assigned to.
Either use the VLAN and PVID (same number) for an access port where you connect computer, devices, or switches without VLAN tag, or use a port for trunk carrying the VLAN ID in the tag. You need to become clear about the difference.
The PVID 1 will assign untagged frames flowing into the switch port to the VLAN 1, the PVID 12 will assign untagged frames to the VLAN 12.
Tht why you can only configure -one- PVID on a port (or LAG).
Your config for g5 with the PVID 20, but the port is member of the VLAN 1 and 12 only (tagged or untgged).
Or do you like to intend configure black hole for untagged frames flowing into the switch?
- vescovoAug 11, 2024Aspirant
Hi.
Thanks for your reply but you wrote things I already know.
I try to simplify my question: what following config is useful for (if it could be...)?
PVID:1 Member:2 Tag:none
Bye
V.
- schumakuAug 11, 2024Guru - Experienced User
Like g5 example I've alredy explained, g2 config does not make any sense, too.
Untagged frames will be assigned to the VLAN 1 (as per the PVID config), but since it's only an untgged member of the VLAN 12, no communication can ever be estblished. Yet another black hole.
Ok.
No sense/weird/useless was our verdict too.
But... (only because I'm on holiday, on normal day I go on without posting stuff :))
PVID:1 Member:1 Tag:2
This is a werid configuration too and OS return an error on saving it. Why it doesn't act the same on all weird/nonsense/incongruent configs?
Why Member+Tag are "bounded" and PVID+Member are not?
Thanks
V.
