vescovo
Aug 10, 2024Aspirant
PVID vs VLAN member vs VLAN tag
Hi All! First day on holiday but still thinking about some hypotesis I talked with a collegue of mine on last day of work. Please see here: I know that "standard" config is (ie): P...
vescovo
Aug 11, 2024Aspirant
Hi.
Thanks for your reply but you wrote things I already know.
I try to simplify my question: what following config is useful for (if it could be...)?
PVID:1 Member:2 Tag:none
Bye
V.
schumaku
Aug 11, 2024Guru - Experienced User
Like g5 example I've alredy explained, g2 config does not make any sense, too.
Untagged frames will be assigned to the VLAN 1 (as per the PVID config), but since it's only an untgged member of the VLAN 12, no communication can ever be estblished. Yet another black hole.
