neverbesuccessf
Jan 13, 2018Aspirant
Questions concerning VLAN on GS108Ev3
Hi there I'm building a network right now and I'm configuring my switch on which leads to the router and then into the network. Short questions about the VLAN: A) Have I configured the VLANs corre...
- Jan 14, 2018
Ref. the VMs ... it depends on how the interfaces are configured - on the virtualisation host as well as on the VM itself. A system can handle just an untagged network, or multiple services which can talk or offer services to multiple VLANs can be configured for tagging (multiple virtual interfaces), so the port can be either dedicated to one VLAN (untagged), or as a VLAN trunk handling access to multiple VLANs.
schumaku
Jan 14, 2018Guru - Experienced User
neverbesuccessf wrote:- I will have 3 zones, network (router), DMZ (Webserver, Mailserver and PBX-Server) and LAN zone (Printer, Clients, Phone)
VLAN-plan:
1: WLAN
2: PC
3: VOIP
4: Printer
This is what I was talking ref. tie up - wiht a single LAN zone, keep PC, printer, WLAN (your trusted devices), use a single VLAN. Sorry for the confusion.
schumaku
- Apr 12, 2023Retired_Member
