Blair2201
Mar 11, 2022Tutor
GS116Ev2 - Can't log into Prosafe - Command is not supported by agent
I've just installed a new switch GS116Ev2 and have trouble logging into ProSafe. I open the utility, enter the default password and receive a message "Command not supported by agent". Has anyone...
- Mar 11, 2022
Hi Blair2201,
It's most likely that the management mode is set to Web browser only if your firmware is v2.6.0.43 or newer (please check the release notes here).
That being said, you'll need to access the switch using a web browser instead (please refer to this KB article on how to do so).
JeraldM
NETGEAR Community Team
JeraldM
Mar 11, 2022NETGEAR Employee Retired
Hi Blair2201,
JeraldM
