DougShuffield
May 21, 2019Tutor
GS752TPv2: POE enable / disable via SNMP
I noted there is an existing thread on this topic in german that ends with a private message (https://community.netgear.com/t5/Smart-Plus-Smart-Cloud-Switches/Switch-GS752TPv2-POE-Admin-enable-disabl...
- Jun 06, 2019
I bring this thread to conclusion and help anyone that has this issue in the future, my resolution was to purchase (for about $300 more than the GS752TPv2) the GSM7248P (M4100 Series) switch which supports the Power Ethernet MIB (RFC-3621).
Netgear, please do not remove RFC-3621 support from the GSM7248P!
Doug
Anonymous
May 23, 2019
Thanks for your suggestion!
We will push R&D to evaluate the feasibility to support private SNMP mib on these Smart Switch samples.
EricZ
DougShuffield
Jun 06, 2019Tutor
Doug
