vasileiosg
Jan 22, 2017Aspirant
Multiple port tagging
Hello, I have a complicated question so please bare with me for a moment. I have an ESXi 6.5 host that is running a virtual Sophos UTM 9.4 appliance. I also have a Netgear GS108Ev3 managed sw...
- Feb 07, 2017
Since you have confirmed that the PC where the ESXi 6.5 host which runs a virtual Sophos UTM 9.4 appliance is a VLAN-aware device, have you checked if tagging is enabled on the physical LAN adapter of the PC? Kindly check this link as a guide on how to check it on your PC.
Also, kindly post images of your actual network setup that especially shows the PC where the ESXi 6.5 host which runs a virtual Sophos UTM 9.4 appliance is connected to the GS108Ev3.
DaneA
NETGEAR Community Team
DaneA
Jan 30, 2017NETGEAR Employee Retired
If ever the 2 physical devices are not VLAN-aware, ports 1 and 2 should be set as untagged ports on VLAN 2 with a PVID = 2.
Let me share this VLAN set-up example using a GS108Ev2 switch that I found online, click here and use it as a guide. Hope it helps.
DaneA
vasileiosg
Jan 30, 2017Aspirant
Now i understand! OK i am going to test it over the weekend and come back to you, thanks a lot!
