jsit
Dec 07, 2019Guide
Offline Registration Key
Just purchased a GS110TPv3 switch and am in the process of initially configuring it offline. Now I need a registration key. I registered it in the mynetgear.com site, but dont see a registration key ...
- Dec 18, 2019
Hi jsit ,
Sorry about the experience on activation key of my.netgear.com.
And this probably issue of my.netgear.com is under analysis , we will update to you while get feedback from developer team.
Otherwise, I have a workaround to get activation key for you.
I will take about 5 minutes for you and No need to connect switch with Internet.
Please reference following step to get the key, it's free to get this workaround works.
1. Install NETGEAR insight application from iOS App Store,
or from Android Google play store.
2. Login with NETGEAR account which registered this switch GS110TPv3.
3. After login with NETGEAR account successful.
Please click on the switch name under "My Other NETGEAR Products"
4. Please click on the button of "Registation Key".After insight load the screen of device.
5. You will find the Registation Key(activation key)for your device GS110TPv3.
6. Please remember this key and keep it private not share to others.
Then Input the Key on Switch Local GUI to unlock all GUI functionality.
7. Enjoy with GS110TPv3.
Here is screenshot of my locally verification.
Hope it works for you.
Thanks,
Daniel.
schumaku
Dec 11, 2019Guru - Experienced User
Hello IphieChen
Can you please clarifiy the registration process?
IphieChen wrote:Sorry for the inconvenience when you try to access device functionality offiline. We understand the frustration caused to you from our Smart Pro switches. So we are going to release a new firmware to enable "registration key" to all the Smart Pro switches with Insight Cloud/Remote Management on December 14.
We understand that all these switches get the local Web UI control allowing entering the Registration Key. That far, that good.
IphieChen wrote:Please stay tuned for the firmware release and use the "registration key" to access device management interface after registering the product.
So can we retrieve this Registration Key from the registered products list on our Negear account then, too?
TIA,
-Kurt
jsit
Dec 11, 2019Guide
@ schumaku
Kurt, this is exactly what I would have thought too. I registered my device in our MyNetgear account, it shows up, but when I click it to view details I would habe thought the registration key would be available there, but as everyone can see, its clearly not.
So, when you access the device management site, it tells you to register the device to obtain the offline registration key. So thn you register the device but aren't given a registration key! This is ridiculous...
So, when
