tantony
Jun 27, 2019Luminary
Remove PVID fromport
How can I remove the PVID from the port? I can chang it, but how do I remove it from ports 25-26? Please see the attached image.
- Jun 27, 2019
You can't remove it. There must be a PVID configured designating the VLAN untagged incoming packets will be sent to. Granted - it might look interesting if only having (or allowing) tagged traffic on a trunk, but still, it has to be there.
schumaku
Jun 27, 2019Guru - Experienced User
tantony
Ok thank you.
