stevenbui22's avatar
stevenbui22
Request Letter of Volatility
Note: I realize GS105 is not a Managed Switch, but I had to select a location.
I need Letter of Volatilities for the following products: GS105NA and JGS524E-200NAS.
v/r,
Steven Bui
  • Hi stevenbui22,
    Welcome to our community! :)
    Here is the letter of volatility for GS105NA and JGS524v2. No password needed and the link will expire after 48 hour period.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi stevenbui22,
ProSupport for Business
