danieli-nello
Jan 30, 2023Aspirant
S3300-52X-PoE+ Change SFP+ port speeds to go into regular SFP
We have a secondary switch (GS728TPV2) that we would like to connect to our primary switch (S3300-52X-PoE+) through SFP but are running into issues with what I believe to be the differences in speed....
schumaku
Jan 31, 2023Guru - Experienced User
Using fiber modules? Please understand that fiber does not know anything similar to the automatic link speed negotiation we know from RJ45 copper ports on 10GbE, 1 GbE and Fast Ethernet. It's the fiber module defining the link speed. To establish a GbE fiber link between a switch port with SFP+ and a switch with an SFP port, you need the same spec'ed fiber link modules.
- danieli-nelloFeb 07, 2023Aspirant
When you say modules, are you talking about the physical modules with in the switches?
I am using a Netgear AXC761-1000S cable. From my reading, I have to use a cable that has an SFP transceiver on one end, and an SFP+ transceiver on the other to make the connection.
- schumakuFeb 07, 2023Guru - Experienced User
The Netgear AXC761-1000S cable is a pure passive 1m long SFP+ Direct Attach Cable. With both ends plugged into a compatible SFP+ 10G port, a 10 Gigabit link speed is expected in both directions.
Not sure on how I should understand the problem description - this is possibly what you would expect between the S3300-52X-PoE and the other GS728TPV2 switch?
The only thing coming into my mind is that not all SFP+ devices can be operated on such SFP+ DAC connections.
Just for my curiosity, the SFP+ port in the S3300 is configured as a general use Ethernet, not as a stacking port?
I was hoping the transceivers on the Netgear cable would be able to transmit at both 1 G and 10 G, in the same way that RJ45 can transmit at both 1 G or 100 MB. This appears to not be the case, so I will get a custom cable with with transmitters capable of this.
