danieli-nello
Jan 30, 2023Aspirant
S3300-52X-PoE+ Change SFP+ port speeds to go into regular SFP
We have a secondary switch (GS728TPV2) that we would like to connect to our primary switch (S3300-52X-PoE+) through SFP but are running into issues with what I believe to be the differences in speed....
danieli-nello
Feb 07, 2023Aspirant
When you say modules, are you talking about the physical modules with in the switches?
I am using a Netgear AXC761-1000S cable. From my reading, I have to use a cable that has an SFP transceiver on one end, and an SFP+ transceiver on the other to make the connection.
schumaku
Feb 07, 2023Guru - Experienced User
The Netgear AXC761-1000S cable is a pure passive 1m long SFP+ Direct Attach Cable. With both ends plugged into a compatible SFP+ 10G port, a 10 Gigabit link speed is expected in both directions.
Not sure on how I should understand the problem description - this is possibly what you would expect between the S3300-52X-PoE and the other GS728TPV2 switch?
The only thing coming into my mind is that not all SFP+ devices can be operated on such SFP+ DAC connections.
Just for my curiosity, the SFP+ port in the S3300 is configured as a general use Ethernet, not as a stacking port?
- danieli-nelloFeb 07, 2023Aspirant
I was hoping the transceivers on the Netgear cable would be able to transmit at both 1 G and 10 G, in the same way that RJ45 can transmit at both 1 G or 100 MB. This appears to not be the case, so I will get a custom cable with with transmitters capable of this.
- schumakuFeb 07, 2023Guru - Experienced User
Afraid, this won't be possible neither with the all passive SFP+ cable (obvious, think about it) nor with SFP+ fiber modules (no speed auto negotiation!).
The only media knowing about auto speed negotiation would be plain copper Ethernet modules.
I understand there is no auto negotiation in the cable or transceivers, but can this not be set within the switch itself? You are able to choose the speed, duplex, and toggle auto negotiation for other ports, but not SFP?
