danieli-nello
Jan 30, 2023Aspirant
S3300-52X-PoE+ Change SFP+ port speeds to go into regular SFP
We have a secondary switch (GS728TPV2) that we would like to connect to our primary switch (S3300-52X-PoE+) through SFP but are running into issues with what I believe to be the differences in speed....
danieli-nello
Feb 07, 2023Aspirant
Oh I think I understand, you are saying I could get the 1 G connection by simply having a regular SFP module on both ends, and the port itself can downgrade?
schumaku
Feb 07, 2023Guru - Experienced User
Yes, this makes a workable 1G fiber link, also on the S3300 SFP+ port.
- danieli-nelloFeb 07, 2023Aspirant
Fantastic, thanks again!
- schumakuFeb 07, 2023Guru - Experienced User
A much more affordable solution using SFP fiber modules from the free market 8-)
Yep, already looking on https://www.fs.com/ they seem to have what I need.
