miltonreg's avatar
miltonreg
S3300-52x won't boot after firmware update 6.6.4.25
Hi,
After performed a firmware update on a stack of 4 S3300-52x, none of them are booting back. It's been 1 hour after the process and I do not know if it's safe to turn them off and back on again.
Any idea?
Help me please...
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    miltonreg,
    Welcome to the community! :)
    You may try to turn it off then turn it back on again.  Observe the behavior of the LED lights.  Then, check if can access the web-GUI of the S3300-52X stack.
    If the S3300-52X won't boot up normally, I suggest you to open a support ticket with NETGEAR Support here as soon as possible for further investigation.
    DaneA
    NETGEAR Community Team
ProSupport for Business
