jjmarcos
Dec 15, 2021Aspirant
Setting up IP ACLs
Hello Netgear community, It's my first post here, whoever is reading this post, thank you and it's nice to e-meet you! I need some help setting up IP ACLs in my switch, a XS716T running the offi...
jjmarcos
Dec 16, 2021Aspirant
The images/screenshots are now appearing.
Any insights about this will be greatly appreciated.
Thanks!
- jjmarcosDec 20, 2021Aspirant
It seems, I'm replying just to myself. But it is what it is :smileyindifferent:
Anyway, found this article:
https://howdoesinternetwork.com/2012/allow-vlan-access-but-no-back
My conclusion after doing some research is that my XS716T switch does not support what I intend to do. There is no way I can specify the type of the TCP flag. Hence, I cannot set that "established" one the article is mentioning.
The closest approach I've got is that I was able to block ping / ICMP traffic from the VLAN 50 to the VLAN 1 and not the other way around. But the actual application traffic still flows. So, I can still open an SSH session from a machine on VLAN 50 to another one on VLAN 1, which was one of the things I wanted to avoid.
Regards
