Kgey181's avatar
Kgey181
Setting up VLAN and DHCP
Hello community, for some time now I have bee tinkering with setting up VLANs on my network. I have read and watched a number of explinations which explain what a VLAN is "literally" without going ...
  • DaneA's avatar
    Aug 10, 2020
    Kgey181,
    Through "Switching/VLAN/Advanced/VLAN membership" - I set port 13 to "T" leaving 24 blank.(Should I also have change this to "T"?)
    Is the Unifi AP-AC LR a VLAN-aware device?  If yes, then port 24 should be set as tagged  (T) port with a PVID of 1.  Port 24 should be a member of all VLANs.
    Why I put the heart in was I'm unsure if I should have used 10.0.100.0/24 to get the interface address of 10.0.100.1.
    The 10.0.100.0/24 is the network address.
    Must any port that is a member of more than 1 VLAN be set as "T" for each VLAN that it is a member of?
    Tagged (T) ports are referred as trunk ports.  The ports wherein VLAN-aware devices are directly connected should be set as tagged ports with a PVID of 1 and it should be a member of all VLANS.  Examples of VLAN-aware devices are Access Points and VoIP phones.
    Will I have an issue with the Telstra SmartModem also being a DHCP server?
    Is the Telstra SmartModem a modem-only device or a modem-router combo?  If its a modem-router combo, then you have a Double NAT setup because the UniFi USG router is connected behind it.  To know more about Double NAT, click here.
    If I wanted the NAS to be used on VLAN100 as well will I also need to set its port (8) to "T" for both and associated PVID's?
    If your NAS is a VLAN-aware device, you will need to set port 8 (I believe that is where the NAS is connected because it is not labeled on the network diagram) as a tagged port with a PVID of 1. Port 8 should be a member of all VLANS.
    DaneA
    NETGEAR Community Team
ProSupport for Business
