PaulBush
May 07, 2021Aspirant
Simple VLAN Setup
I would like to setup what I would think would be a simple wired 2 VLAN setup. One VLAN for all my home devices and one VLAN for my work computer. I would like them to not have access to each other o...
DaneA
May 13, 2021NETGEAR Employee Retired
Welcome to the community! :)
In searching these forums it appears I may need a VLAN aware/capable router. Was hoping all the features I needed were in the switch.
Yes, you will need a VLAN-aware router that will serve as DHCP server to the VLANs you have configured to the GS324TP. The GS324TP does NOT have the capability to provide DHCP service since it is a Layer 2 switch.
Here is an example of the setup that you need. Let me share the article below and use it as your guide:
How do I set up one or more VLANs between a NETGEAR ProSAFE firewall and a smart switch?
DaneA
NETGEAR Community Team
- PaulBushMay 18, 2021Aspirant
Thank you very much for your help.
