nicke20
Jul 11, 2020Aspirant
smart poe switch closing down ports
I recently bought the above switch to make my home network a bit neater, has a router going in and a ubiquiti cloud key plugged in running 4 wireless ap's it then has a bout 10 devices plugged direct...
- Jul 11, 2020
Tha'ts the classic Sonos STP/l2 loop issue - if all Sonos players are wired, disable WiFi...
FWIW: The L2 loop existed before on your unmanaged switches - but you have never realized there is a problem and the network failed to perform well.
nicke20
Im hoping i have cured my L2 loop myself
sonos play 1 wired and picking up wifi, one from one branch of main switch one from another
ill look at it all againn tommorow
schumaku
Jul 11, 2020Guru - Experienced User
