dthillsr's avatar
Aug 07, 2020
Stacked Sswitches momentary drops
We have three GS752TXS switches stacked together. All three switches will drop the internal connections tol all of our computers for usually less than a minute and then restore the connections withou...
  • dthillsr's avatar
    dthillsr
    Aug 16, 2020
    I believe we have found the problem. It appears to have been caused by the battery backup blinking of and not sending power to the switches. We have moved the power cords to a different UPS last Thursday evening and have not had the problem since.
ProSupport for Business
