dthillsr
Aug 07, 2020Tutor
Stacked Sswitches momentary drops
We have three GS752TXS switches stacked together. All three switches will drop the internal connections tol all of our computers for usually less than a minute and then restore the connections withou...
- Aug 16, 2020
I believe we have found the problem. It appears to have been caused by the battery backup blinking of and not sending power to the switches. We have moved the power cords to a different UPS last Thursday evening and have not had the problem since.
DaneA
Aug 09, 2020NETGEAR Employee Retired
Welcome to the community! :)
What is the current firmware version of the GS752TXS stack? If ever its not yet the latest version, I suggest you to update it. The latest GS752TXS firmware is v6.1.0.39 and you can download it here.
What is the model of the SFP modules you are using for the stack?
DaneA
NETGEAR Community Team
dthillsr
Aug 12, 2020Tutor
Where do I find what SFP modules that I am using?
- DaneAAug 16, 2020NETGEAR Employee Retired
Kindly check the SFP modules itself. It is labeled on it.
DaneA
- dthillsrAug 16, 2020Tutor
