duncan9322
Apr 18, 2022Aspirant
Steps to change the management VLAN for the GS108Tv3
Hi all, Would anybody be so kind as to provide the steps to change the management VLAN from 1 to 1001? The GS108Tv3 is connected to another switch that has tagged VLANs 1 and 1001 on port 1 and a w...
- Apr 19, 2022
Welcome to the community! 🙂
By default, VLAN 1 is the Management VLAN and all ports are members of VLAN 1. Since VLAN 1001 is already created and all ports are still members of VLAN 1, you need at least one port to be a member of VLAN 1001 (for example: port 8). Then, you may now change the Management VLAN from VLAN 1 to VLAN 1001 via the web-GUI. In order to manage the switch, you need to connect a PC/laptop directly to port 8 to be able to manage the switch.
DaneA
NETGEAR Community Team
DaneA
Apr 19, 2022NETGEAR Employee Retired
DaneA
- duncan9322Apr 19, 2022Aspirant
I hadn't set up the PVID on the workstations port. Many thanks for your help DaneA and Retired_Member.
Connect an untagged cable to g1 (my workstation)
Connect a workstation to g8
Factory Reset - press the reset button in until all the port light uplogin with the default "password"
change the password
log in with the new password
System 🠊 Management 🠊 IP Configuration
set a static IP address. [Apply]
Switching 🠊 VLAN 🠊 Basic 🠊 VLAN Configuration
VLAN ID = 1001, VLAN Name = LAN [Add]
Switching 🠊 VLAN 🠊 Advanced 🠊 VLAN Membership
VLAN ID 1 remove untagged from g8 [Apply]
VLAN ID 1001 add untagged to g8 [Apply]
Switching 🠊 VLAN 🠊 Advanced 🠊 Port PVID Configuration
select g8, PVID = 1001. [Apply]
set Management VLAN ID = 1001 [Apply]On the workstation
Remove the cable from g1
VLAN ID 1 add tagged to g1 [Apply]
VLAN ID 1001 add tagged to g1 [Apply]
Insert a VLAN tagged cable in g1Kind regards,
Duncan
