duncan9322's avatar
duncan9322
Steps to change the management VLAN for the GS108Tv3
Hi all, Would anybody be so kind as to provide the steps to change the management VLAN from 1 to 1001? The GS108Tv3 is connected to another switch that has tagged VLANs 1 and 1001 on port 1 and a w...
  • DaneA's avatar
    Apr 19, 2022
    duncan9322,
    Welcome to the community! 🙂
    By default, VLAN 1 is the Management VLAN and all ports are members of VLAN 1.  Since VLAN 1001 is already created and all ports are still members of VLAN 1, you need at least one port to be a member of VLAN 1001 (for example: port 8).  Then, you may now change the Management VLAN from VLAN 1 to VLAN 1001 via the web-GUI.  In order to manage the switch, you need to connect a PC/laptop directly to port 8 to be able to manage the switch.
    DaneA
    NETGEAR Community Team
ProSupport for Business
