DarkZeroThirtee
Sep 16, 2019Aspirant
Switch Standards
Hello, everyone, I have a question about the switch XS708T, 10-Gigabit-Smart-Managed-Pro. What LAN standards is it backward compatible with? I have only found information containing 1 GbT and 1...
- Sep 16, 2019
@ all
I have a solution that is really smart.
I buy a 10GbT NIC and install it into the PC. A PCI-e 3 x 16 interface is still available on the PC. Then the PC is ready for 10GbT. The NIC costs about 99,- €.
DarkZeroThirtee
The XS724EM is not an alternative. 24 ports are clearly too many and beyond the budget.
My solution would be a switch with the following specifications:
max. 8 ports (1GbT, 5GbT, 10GbT)
Regarding the XS708T:
An alternative could also be GBIC which can be built into one of the two SFP+ slots. It would only have to support 5GbT or am I making a mistake?
Does Netgear offer something like this or can you take any one?
DaneA
Sep 16, 2019NETGEAR Employee Retired
The XS512EM switch has 12 RJ-45 copper ports that supports 100M/1G/2.5G/5G/10GBASE-T.
The 1G/10G SFP+ ports of the XS708T are shared (or combo) ports. The XS708T does not support 5GBASE-T.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
- DarkZeroThirteeSep 16, 2019Aspirant
@ all
