tonynsx
Apr 16, 2019Luminary
Switch web gui
I have a XS728T and GS724TS. I noticed that the web gui for the GS724TS is "old fashioned" compared to the XS728T. I have to put my browser on compatability mode just so I can view the GS724TS web ...
- Apr 17, 2019
Hi tonynsx,
I have a XS728T and GS724TS. I noticed that the web gui for the GS724TS is "old fashioned" compared to the XS728T. I have to put my browser on compatability mode just so I can view the GS724TS web gui. I'm using the same browser for both switches.
The GS724TS switch is already EoL (End of Life). There will be no future fix or new firmware that will be released since this switch has been discontinued.
Also, I have one switch on VLAN 2, and another switch on VLAN 3. What would happen if I connect a dummy switch to these two switches? How would the dummy switch know which VLAN to use? Would it be random?
It depends on the ASIC (Application-Specific Integrated Circuit) of the switch, and the switch itself. New switches (with E such as GS108Ev3) will likely pass through (based on MAC table). On older, non-E switches (unmanaged switches), it would fail CRC and drop the packet. E-switches without VLANs may still be aware of VLANs and be able to pass them through.
It is advisable that you should not deploy an 802.1Q unaware switch in a network wherein you have expectation of persevering 802.1Q traffic.
DaneA
NETGEAR Community Team
DaneA
Apr 17, 2019NETGEAR Employee Retired
Hi tonynsx,
DaneA
