Jan_B's avatar
Jan_B
Follower
Feb 08, 2021
Switch with ability to set 802.1p priority for VLANs
Hello!
I wish to replace ISP-provided router with my own. Unfortunatelly due to IPTV provisioning, setup is quite complicated, requires both router and switch, and I have problem to identify switch with proper functionality. My GS108Ev3 didn't manage.
I need two features:
- ability to define VLANs (with tagged and untagged ports) - this is not a big deal and GS108Ev3 does it
- ability to define 802.1p priorities for defined VLANs
To be precise I need 3 VLANs:
- 35 with no defined priority
- 838 802.1p=4
- 839 802.1p=5
Can you please suggest me which switch will be able to cover this? 8 ports are needed.
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Jan_B,
    Welcome to our community! :)
    Thank you for choosing NETGEAR! Please check the GS108Tv2 that supports 802.1p COS. You may purchase it directly from our authorized resellers.
    Please close this thread by clicking the "Accept as solution" if you find this reply helpful.
    John
    NETGEAR Community Team
ProSupport for Business
