maxxiger
Feb 20, 2021Follower
Synology Guest WiFi (VLAN ID 1733, Synology mesh WiFi system) with Netgear GS752TPP Switch
Hello everyone, I have been trying for a few weeks to set my Netgear GS752TPP switch so that the guest WiFi works with my Synology RT2600AC and Synology MR2200AC. Unfortunately without success. ...
schumaku
Apr 03, 2021Guru - Experienced User
ppcina wrote:And how should be setup ports between switches in "Case A" if I have more then one swich ?
You configure trunk ports on both sides to connect the switches as shown in the Case A. The base VLAN will run untaged, the Guest VLAN will run tagged.
ppcina
Apr 16, 2021Aspirant
Thank you very much for help. WiFi finally works.
