tantony
Jul 15, 2019Luminary
Trunk Vs. Untagged multiple VLANs
Sorry if I'm in the wrong forum. Let's say I have 2 VLANs. VLAN 5 = IT, VLAN 10 = Admin What's the difference between making a port trunk (T), then adding both VLANs, and making a port unta...
- Jul 15, 2019
tantony wrote:Port 23:
VLANs 5,10 both (T), PVID 5
Port 23:
VLANs 5,10 both (U), PVID 5
They both do the same thing?
No.
The first is a direct "trunk" type port carrying multiple tagged VLANs.
The second one is a config you should avoid in general - as it does create some asymmetrical VLAN ... while the VLAN ID 5 (with PVID 5) will work for incoming and outgoing traffic, there will be also VLAN ID 10 traffic flowing off the switch, but not back to that VLAN. Simple: You can't have more than one VLAN untagged on a port. Anything else is of theoretical and academic value only.
schumaku
Jul 15, 2019Guru - Experienced User
Port 23:
No.
tantony
Thank you. So just to make sure I understand it clearly, method 2, where I made port 23 untagged (U) with both VLANs, might or might not work depending on the circumstances, but is not a good practice.
- schumakuJul 15, 2019Guru - Experienced User
Take the second one as an academical solution only. For us, the aim of VLANs is to create independent broadcast domains - with the second config you mix things up.
