tantony
Jul 15, 2019Luminary
Trunk Vs. Untagged multiple VLANs
Sorry if I'm in the wrong forum. Let's say I have 2 VLANs. VLAN 5 = IT, VLAN 10 = Admin What's the difference between making a port trunk (T), then adding both VLANs, and making a port unta...
- Jul 15, 2019
tantony wrote:Port 23:
VLANs 5,10 both (T), PVID 5
Port 23:
VLANs 5,10 both (U), PVID 5
They both do the same thing?
No.
The first is a direct "trunk" type port carrying multiple tagged VLANs.
The second one is a config you should avoid in general - as it does create some asymmetrical VLAN ... while the VLAN ID 5 (with PVID 5) will work for incoming and outgoing traffic, there will be also VLAN ID 10 traffic flowing off the switch, but not back to that VLAN. Simple: You can't have more than one VLAN untagged on a port. Anything else is of theoretical and academic value only.
schumaku
Jul 15, 2019Guru - Experienced User
Port 23:
No.
nagraiv
May 28, 2025Aspirant
I was actually wondering why my Netgear switch allows multiple untagged VLANs on the same port.
What is the point of that?
I never do that, I only just have on untagged VLAN per port (and I always forget that I also need to set the port's PVID to that VLAN... my other switches only allow me to set 1 untagged VLAN and that is the PVID, with Netgear I have to do both since they allow multiple untagged VLANs).
