tonynsx
Nov 10, 2020Luminary
Types of 10 Gb cables for trunk
I have two 10 Gb Netgear switches on two sides of the server room, about 20 feet of each other. Right now, the trunk is only 1 Gb because I'm using a Cat 5 cable. I would like to make the trunk 20 Gb...
- Nov 12, 2020
Links participating in a LAG should run on similar speed and latency. It's the LAG operating the trunk - so be careful that you set the VLAN config on the LAG, not the individual link.
