thierry8p
Oct 07, 2019Guide
Unable to change the default password on Switch
I am on mac osX 10.13.6 I cannot change the password on the switch GS308E I paste the new password in After clicking Apply nothing happens Note to Netgear: I can't beleive the default passwor...
- Oct 07, 2019
WOW, I just found the solution to the issue.
When pasting, there is a Javascript that does NOT get activated. Unless a key is TYPED in.
Pasting the password, adding a space and deleting the space triggers the JS...
Then "Apply" works.
To be fixed in front end code to allow pasting.
thierry8p
Oct 07, 2019Guide
Then "Apply" works.
