sckeith
Jul 09, 2022Follower
UNable to update GS108Ev3
Hello I've have 2 GS108Ev3 switches for several years with no problems. I went to install the latest firmware but received an error. I can log into both switches with no problems and check th...
schumaku
Jul 09, 2022Guru - Experienced User
Hello Steve,
There is not much of a difference from the earlier 2.06.16 released about a year go to .17 firmware image binary.
sckeith wrote:
... It does this on 2 PC's whether or not I run ProSafe Plus Utility as administrator on Windows 11
Had used the legacy utility for earlier updates, and had operated Windows 11 back then already?
Note: Any references to the ProSAFE Plus Utility (for discovery, operations and firmware updates) and NETGEAR Insight app (for discovery) was removed with the may 2022 update of the Gigabit Ethernet Plus Switches User Manual.
Only the "Download and update the firmware" (p.61 ff. from the UM referred above) using a web browser are the only processes supported.
In case you need to discover the switch IP on your LAN, follow the "Use the NETGEAR Switch Discovery Tool to (discover and) access the switch" as shown on the same UM p.20.
-Kurt
- Apr 12, 2023Retired_Member
