RBee
Oct 24, 2019Tutor
VLAN Membership vs PVID
Hi all, I'm new to managed switches, and just had a quick question... If I'm setting up multiple VLANs, I'm wondering what the difference is between the VLAN Membership settings (where you click on...
- Oct 24, 2019
The PVID is used for VLAN which is run untagged on the switch port - and does define the VLAN where the untagged switch incoming traffic is associated to.
schumaku
Oct 24, 2019Guru - Experienced User
