RBee
Oct 24, 2019Tutor
VLAN Membership vs PVID
Hi all, I'm new to managed switches, and just had a quick question... If I'm setting up multiple VLANs, I'm wondering what the difference is between the VLAN Membership settings (where you click on...
- Oct 24, 2019
The PVID is used for VLAN which is run untagged on the switch port - and does define the VLAN where the untagged switch incoming traffic is associated to.
RBee
Oct 24, 2019Tutor
So, if I only have untagged traffic, is it ok to assign the PVIDs and the VLAN memberships 1:1?
ie. vlan 1 = ports 1-4 untagged, and PVID 1 for ports 1-4
vlan 10 = ports 5-8 untagged, and PVID 10 for ports 5-8
etc...
schumaku
Oct 24, 2019Guru - Experienced User
RBee wrote:ie. vlan 1 = ports 1-4 untagged, and PVID 1 for ports 1-4
etc...
Excellent example! Yes, this will assign incoming untagged packets (to the switch) to the VLAN 1 for ports 1-4, and the VLAN 10 for ports 5-8. This will set-up the two port set's like independent switches.
