benn_1703
Jul 23, 2020Aspirant
VLAN tagging and PVID
Hi, I am new to Netgear switches so apologies if I have missed something basic, I have a HP switching background. I have come across a port configuration which has the same VLAN as tagged as ...
- Jul 23, 2020The untagged config for 300 does make the switch removing the tags on outgoing frames, the PVID 300 config does add the tag for VLAN 300 assigning the untagged traffic to the VLAN 300.
benn_1703
Hi,
Thanks for the reply.
Unfortunately I only have CLI outputs for this switch. From what I gather from the reply it would appear the PVID takes precedence over the VLAN tagging statement and therefore the VLAN 300 traffic would be seen as untagged in this instance.
It was more so for me to understand to behaviour of such a port config where historically from what I have seen if you had a PVID set and then added it also the same VLAN ID as tagged you would only have one or the other.
schumaku
Jul 23, 2020Guru - Experienced User
