Silvioi's avatar
Silvioi
VLAN tagging using CLI
Hello,
I am trying to configure VLAN tagging/untagging on a port using CLI
but I am not able to find the command for that, this option exist on the web GUI.
Saw some referance for M5300 switch CLI on the web, but the CLI in the MS510TX seems different and I couldn't find
the commands to enable this.
(Using the latest 6.7.0.42
Appricate any help,
Thank you,
Silvio.
  • There is no support for the CLI you mean?
    Since the device does have CLI , anyway I was able to find the answer myself.
    its under - switchport general allowed vlan add XXX untagged
    (or tagged)
    for example :
    conf
    interface TwoPointFiveGigabitEthernet 5
    switchport general allowed vlan add 2000 untagged
    end
  • schumaku's avatar
    schumaku
    There is no CLI support for any Smart Managed Plus and Smart Managed Pro SWitches, including the MS510TX. There are pure Web managed devices.
    • Silvioi's avatar
      Silvioi
      (or tagged)
      for example :
      conf
      end
ProSupport for Business
