kirillmalkin
Jan 13, 2024Aspirant
Where can I locate the version v5.2.0.26 for GS752TXS?
Hi, where can I locate the version v5.2.0.26 for GS752TXS?
schumaku
Jan 13, 2024Guru - Experienced User
Everything on -> https://www.netgear.com/support/product/gs752txs#download -->> ++View Previous Versions
kirillmalkin
Thank you for such a quick reply - found it! Will try to perform staggered upgrade now...
I have another GS752TSX that I already bricked by going directly to 6.1.0.39 and burning both image1 and image2. Is there any hope to recover it?
Thanks again!
- schumakuJan 13, 2024Guru - Experienced User
Afraid, never had to .... I would try to find a way to connect a serial console as shown for example here
- kirillmalkinJan 13, 2024Aspirant
Excellent, thank you so much! I was wondering what these pins were for 🙂
Btw, staggered upgrade on another switch worked just fine.
Thanks again!
