Biggsylad's avatar
Biggsylad
Wierd Network Behavious
HI, I am looking for a bit of advice. I have recently purchased the new Quad band Orbi and it's great, exactly what it said on the box and behaving perfectly.  However, I have this weird problem whi...
  • Biggsylad's avatar
    Biggsylad
    Dec 13, 2022
    Further update!
    So, after connecting a Cat 6   cable from the PC and the same switch as the Mac Pro, I was still getting the same results. After much discussion with various colleagues, one of them suggested going  and downloading TCP optimizer  at this link
    After a quick look around the app and having it look at my setup if found a few missing registry tweeks and as soon as they applied them wallop, speed was back, for sanity, I applied it to the other PC in the office and once again it worked a treat. I still don't know what it was that changed it but it looks like it was a config issue on the systems rather than the switches, which makes sense after connecting the  PC  to the main switch.   I have replaced the SFP modules going from the loft switch down to the  GS110, maybe  that also helped  either way problem solved!
ProSupport for Business
