JeffAtK2
Jan 30, 2020Guide
XS728T FIRMWARE UPDATE INSTRUCTIONS
Hi, The firmware download page says refer to the user manual for firmware update instructions. The user manual ( User Manual ) only acknowledges updates may exist and does not explain how to ...
- Jan 30, 2020
Usually, the Update Procedures are part of the Release Notes - why ever, on the current firmware it appears to be missing.
Check the previous firmware https://kb.netgear.com/000060622/XS728T-XS748T-Firmware-Version-6-5-1-36 for the Update Procedures, use the similar process with the current version number.
schumaku
Jan 30, 2020Guru - Experienced User
JeffAtK2
Jan 30, 2020Guide
Thank you!! That's exactly what I was looking for.
Jeff
