Pablo7
Apr 23, 2025Follower
XS748T as a static gateway/router? Inter VLAN routing?
We have an XS748T and have recently signed on for a new Internet service with a /29 address range. It has been my past experience most of the time that an ISP will just hand you your /29, reserve one...
schumaku
Apr 24, 2025Guru - Experienced User
These switches scan perfectly do short cut IPv4 routing in between two or more IP subnetworks. Say for example 10.1.1.0/16 <-> 172.20.1.0/16.
What these routers will never do is what a typical consumer/SMB router does: NAT. Network Address Translation for hiding your 192.168.1.0/24 network behind the main 100.111.0.1 WAN IP. For such purposes you need a fully blown router (and security appliance). With these you can define multiple LAN subnets for Many2one NAT, and much more.
